Quellcode |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 |
int temp1 = 30;
int speed1 = 20;
int temp2 = 40;
int speed2 = 40;
int temp3 = 50;
int speed3 = 60;
int temp4 = 60;
int speed4 = 80;
int speedMax = 100;
int AI_TMP36 = 0; //THIS IS P5, P5 is Analog Input 0, so when you are using analog read you refer to it as 0
int time= 20;
int temp[10];
int temperature = 0;
int AI_potentiometer = 3;
int manualAdjust = 0;
int AO_clkAmplifier = 4;
int clkOutputPercent = 0;
int clkOutputValue = 0;
int DO_greenLed = 0;
int DO_yellowLed = 1;
int DO_redLed = 2;
void setup()
pinMode(AO_clkAmplifier, OUTPUT);
pinMode(DO_greenLed, OUTPUT);
pinMode(DO_yellowLed, OUTPUT);
pinMode(DO_redLed, OUTPUT);
pinMode(AI_potentiometer, INPUT);
pinMode(AI_TMP36, INPUT);
void loop()
//get average Temperature in Celsius
for (int i = 0; i < 10; i++)
temp[i] = map(analogRead(AI_TMP36), 0, 410, -50, 150);
delay(time);
temperature=(temp[0]+temp[1]+temp[2]+temp[3]+temp[4]+temp[5]+temp[6]+temp[7]+temp[8]+temp[9])/10;
//get manual adjust in Percent
manualAdjust = map(analogRead(AI_potentiometer), 0, 1023, 0, 100);
//calculate clk output in percent, add manualAdjust and then convert in analog output range
if (temperature <= temp1) // Minimal speed
clkOutputPercent = speed1;
if (temperature > temp1 and temperature <= temp2) // Speed2
int m1 = (speed2 - speed1) / (temp2 - temp1); // calculate linear function
int b1 = speed2 - m1 * temp2;
int fx1 = m1 * temperature + b1;
clkOutputPercent = fx1;
if (temperature > temp2 and temperature <= temp3) // Speed3
int m2 = (speed3 - speed2) / (temp3 - temp2); // calculate linear function
int b2 = speed3 - m2 * temp3;
int fx2 = m2 * temperature + b2;
clkOutputPercent = fx2;
if (temperature > temp3 and temperature <= temp4) // Speed4
int m3 = (speed4 - speed3) / (temp4 - temp3); // calculate linear function
int b3 = speed4 - m3 * temp4;
int fx3 = m3 * temperature + b3;
clkOutputPercent = fx3;
if (temperature > temp4) // set maximal speed when temperature > temp4
clkOutputPercent = speedMax;
clkOutputPercent = clkOutputPercent + manualAdjust; // add manualAdjust to rise the speed manually
if (clkOutputPercent > 100) // maximal 100% limiter
clkOutputPercent = 100;
clkOutputValue = (255 / 100 * clkOutputPercent); //convert from Percent to Analog output range
analogWrite(AO_clkAmplifier, clkOutputValue);
// set Temperature Leds
digitalWrite(DO_greenLed, HIGH);
digitalWrite(DO_yellowLed, LOW);
digitalWrite(DO_redLed, LOW);
digitalWrite(DO_yellowLed, HIGH);
digitalWrite(DO_greenLed, LOW);
digitalWrite(DO_redLed, HIGH);
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Naozumi« (27. Oktober 2016, 12:22)
Quellcode |
1 |
if (temperature > temp1 and temperature <= temp2) |
Quellcode |
1 |
if (temperature > temp1 && temperature <= temp2) |
Naozumi (28.10.2016)
//Variables for Fancurve calculation
int temp1 = 30;
int speed1 = 20;
int temp2 = 40;
int speed2 = 40;
int temp3 = 50;
int speed3 = 60;
int temp4 = 60;
int speed4 = 80;
int speedMax = 100;
//Constantes
int DO_redLed = 2;
//Aplication Variables
int temp[10];
int time= 20;
void setup()
void loop()
temp = map(analogRead(AI_TMP36), 0, 410, -50, 150);
delay(time);
the_leon (04.12.2016)
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »misfit« (16. Oktober 2017, 07:07)
misfit (24.10.2017)
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »black_devil« (3. November 2017, 21:32)
