Samstag, 14. Mai 2016, 04:28
so hi guys, forst thanks to you all for your very motivating comments. here is the result of todays modding session.
i carroed on with the interior and i think it should be finished by sunday evening. its a lot of little thingamadjigs and whatchamacallits in pirate style till its done.
anyway here are the pics.
first i made the mid section between the fans and psu. it will hold 6 petg push compressions and will be screwed permannent with the case, it also covers the psu wires too.
yes, even the grafik cards will have certain deck planking too.
wires dont really fit in well in this theme, so this deck planking cover will hide them.
then i thought if the aluminium plate which is holding the 6 petgcompressions is fixed permanently and i want to get behing the connections for some reason on any given day, then i would have to do that from the back, so i changed the plan and made a second plate which is screwed onto the fixed one. this was i can remove the whole block now.
like i said, i dont want wires visible, so i made a stern parapet as cover for the grafik card power supplying cables,
i cut out some windows for better air flow.
i then made a psu mainboard cord cover which is dismantalabe.
i made a deck ladder looking cover, it is dismountable too.
Samstag, 14. Mai 2016, 08:39
Ali, seh ich da Metallbearbeitung? :chainsaw: :rocket: :minigun:
Bist du krank?
Oder is der Regenwald schon zuende :phat:
Samstag, 14. Mai 2016, 09:56
joh, je nach dem as ich wann und wie brauch. 67th, darkknight und pod1 und 2, waren ale mit metal und plexi so wie holz.ich baue gerne mit mmetal und plexi auch aber auch gestern wurde ich wieder daran errinert das holz viel schwieriger ist. oberflächenbehandlung bis fertigung ist ein viel aufwendigere pocess, die genauigkeit von metal und plexi ist geil, aber egal was jeder hier sagt, es ist einfacher zu behandeln.
natürlich ist das was zb ironknocker macht ein liga für sich, aber metal suagt nicht ist glatt etc..
vieleicht mache ich mal ein holzloses pc, we will ob ic ein conzept mal dafür entwickele.
Samstag, 14. Mai 2016, 10:55
@george frag mal bei Greenpeace.
Vllt. unterstützen die bei einem "wir schützen den Regenwald" Contest :phat:
Dienstag, 17. Mai 2016, 12:27
Hehe.
Aber zum Thema Holz vs Metall vs Plexiglas: Ja Holz saugt und ist schwierig zu Lackieren. Dafür lässt es sich sehr einfach in Form bringen und deutlich einfacher korrigieren. Plexiglas wiklich perfekt in Form zu bringen kann deutlich schwiriger sein - und bei unlackiertem Plexiglas hat man noch das "Problem", dass man kleine Macken nicht kaschieren kann - wie es bei Holz unter Lack sein kann.
Dennoch kann Holz wirklich sehr schwierig sein - Sämtliche Funier- und Lackierarbeiten können höchst anspruchsvoll sein.
So pauschal lässt sich das nicht sagen, dass Holz schwieriger oder einfacher ist. :)
Dienstag, 17. Mai 2016, 13:40
hey bud, ja genau das habe ich auch gesagt.
stimmt, bei holz genau so schwierig aber
war eher mein erfahrung, da ich wirklich mit allem gearbeitet habe. ich experimentiere sehr gerne und benutze wirklich alle materialien die es gibt, und die die die es noch nicht gibt ^^ , mit holz kriege ich jeder form hin,
manche sind leicht, andere komplexer. konkurve sachen lasssen sich eher realisieren mit holz als mit metale und plexi, es sei dann mann zeihet tief bei plexi oder ironknocker eisenschmiedisch drauf ist.
der vikings segel hätte er aus alu raus gehämmert wahrscheinlich, aus holz ist es aber genau so stabil und viel leichter zum bauen, wurde eh nicht lackiert, sondern überzogen.
bei filigrane sachen wird es eher schwieriger, wie kleine buchstaben etc.. da ist alu, metale und sogar plexi besser. soll etwas eh lackiert werden und ist fligran und klein, und soll stabil auch sein so wie zum besipiel der hammernde mann der sich bewegt bei PC-Reforged dann plexi.
wo ich überhaupt kein geduld habe ist plexi polieren, ist aber nicht schwierig, sondern einfach bothersome, mühsam. klar hat plexi auch seine tücken, metale auch.
ich denke, alle materialien haben ihre tücken, macken und vorteile auch, aber mein erfahrung mit viele bisher sagt ,
mit holz ist wie beim sex. es will ein vorspiel, ein climax und aber auch eine zigarette danach, dann ist es evtl. zufrieden, aber aber nur nach die massage danach. :thumbsup: :P
Dienstag, 17. Mai 2016, 14:20
Was bei Alu schwierig ist, das vor dem lackieren alle Kratzer und Feilspuren weg sind, diese sieht man gnadenlos.
Das Holz schwierig ist weis ich, hab da so meine Erfahrungen :D
Mittwoch, 18. Mai 2016, 02:14
das ist bei alu tatsächlich so, aber schwierig naja, mühsam vielleicht.
anyway, hier noh a paar fotos. der banner 3d look schaut echt gut aus. die farben sind eher erste primer farben, es ändert sich sehr noch.
here are some more pics, its still just the primer stains brown, red and then black though, will still change a lot. tomorrow some of this color will be sanded off again to reveal some of the wood and give it a used worn weather beaten look.
for staining I am using printer ink in my airbrush.
Mittwoch, 18. Mai 2016, 05:08
Schaut mit etwas Farbe schon gleich ganz anders aus:)
Mittwoch, 18. Mai 2016, 06:15
Was?
Du lakierst schon ;(
Ich dachte da kommen noch 50000 extra fuktionen :phat:
Freitag, 20. Mai 2016, 01:33
Was?
ja, die 50000 funktionen sind schone drin, mindestens.
so hier die erste farb pics. muss noch ein paar mal klar laciert werden.
so here is a little update, well actually 5 coats of sanding, staining, paining glazing etc.. just less pics.
this skull was meant for an aquarium, now i need to make it look a bit grimmer and meaner.
here are some before and after pics.
i used furniture smart remait wax and sawa dust to better the eyes.
<a href="http://s1307.photobucket.com/user/abbas-it/media/Piracy%20and%20Prophecy/19%201rst%20glaze%20and%20skull%20glazed/PICT5934_zpsy0a22ust.jpg.html" target="_blank"><img src="http://i1307.photobucket.com/albums/s592/abbas-it/Piracy%20and%20Prophecy/19%201rst%20glaze%20and%20skull%20glazed/PICT5934_zpsy0a22ust.jpg" border="0" alt=" photo PICT5934_zpsy0a22ust.jpg"/></a>
i amusing printer ink to stain in my ait brush for everything where the wood grain should show through. organic is the word.
one of the gun whale canons will open the dvd drive so i laid a bypass wire for the switch.
i touched up the skull with solver after painting it black.
i did the same by fingering the canons too, make em look a bit more worn metalic looking.
i did the same silver touch up look on the little shield skulls too.
more tomorrow
Freitag, 20. Mai 2016, 17:57
i am now walking the plank and #### everything together, then they will all be wed together. so another update will be on its way tonight, here is the first.
have taken the day and weekend off to finish as much as possible.
so first the main chassis holder has made it upstairs for the final glaze, its sunny today thanks god.
i cut a new bottle with the dremel, the last one had scratches.
the front banner, is now metalic and the swords are mounted.
i dipped these eva foam letters in a wood glue dilution to primer them before painting.
so, the bottles are fixed and waiting to be filled with rum,,,:D
more to come.. tonight..
Freitag, 20. Mai 2016, 19:12
Schaut super aus. Wie lange hast du für das halbieren der Flaschen gebaucht. Packt man das mit einer scheibe oder braucht man mehr?
Freitag, 20. Mai 2016, 20:57
Die Totenköpfe sind super geworden.
Samstag, 21. Mai 2016, 01:02
thanks guys, @ ik, nee ich habe immer noch die erste dremel scheibe und kann wahrscheinlich noch 5 oder 6 flaschen sogar schneiden
ich habe es unter ein laufenden wasserhahn geshcnitten und war überrascht wie gut es ging. habe 2 flaschen bisher geschnitten und böden auch entfernt. pro flasch ca. 3 minuten. ohne wasser wäre es sofort kaputt.
hier ein kleine update..
and here is another little update, seeing as i am wiring the parts while fixing them, it looks as if nothing is really happening in the pics, but it still took all day.
this is the reservoir array which is fixed in one piece behind the bottles.
i am oonly using berstein golden leds in this one to match the rum coolant.
after painting the letters silver, i dabbed the brown and black in to give it a little older look.
Samstag, 21. Mai 2016, 07:41
Ich glaube ich hätte die Flaschen ganz gelassen, unten ein Loch rein gemacht und die Anschlüsse rein geklebt. Einlauf oben.
Somit wäre die ganze Flasche ein AGB gewesen.
AGB hinter der Flasche gefällt mir jetzt nicht so gut.
Samstag, 21. Mai 2016, 08:09
Das hab ich am Anfang schon vorgeschlagen ;(
Aber das Ali hört ja ned auf uns :phat:
Samstag, 21. Mai 2016, 09:02
hat aber ein grund, und ausserdem mir gefällt es auch so, hat was von wein keller so wie sie in szene gesetzt sind. grund steht unten.
du hast mal ein öl pc gebaut und er ist auch undicht geworden, auch wenn nach ein längere zeit. das wäre mit glass und transport schneller gegangen, da das glass irgendwann gebrochen wäre. nee danke. weitere erklärung unten.
ich kann mir nicht errinern ein glass glasche gesehn zu haben als resi. ich meine ein normaler glass flasche, jetzt weis ich warum.
ein extra dafür vorbereitetes wurde vielleicht gehen. als ich die flaschen aufgeshcnitten habe, die sind gar nicht glaich die hälften. was so perfekt als ganze ausschaut ist in manche stellen so dünn durchs glassbläser.
normal heist es no risk no fun, aber hier no risk and keep rum
ich höre schon aber nur wenn es sinn macht. das ist echts glass, ich gehe sicher kein risiko ein.
leute macht es mal mit echtem glass und dann transportiere das ding durch die gegend. ich forder jeder heraus das zu tun in ein case.
alleine durch rein pressen habe ich eins kaputt gemacht.
schneiden war schwer genug, und ich habe auch als lehrgeld 2 flaschen kaputt gemacht.
das sind ganz normaler flaschen die als ganzes ganz stabil sind, aber sobald mann sie irgendwie bohrt und schneiden sind sie eben nicht mehr.
wie ein ei, super stabil, mache ein schnitt oder loch rein, dann eben nicht.
das case hat ein gewicht und arbeitet gegen die spannungen wie immer wenn man es hebt. 1mm reicht und das glass bricht wieder.
so und stellen wir uns vor, es wäre voller wasser. nee danke. und wie gesagt mir gefält das weinkeller zapfsäulen look.
die flaschen sind auch so eingebaut das wenn der hinter teil fallen wurde, die flaschen nicht mit dem boden in berührung kommen, alles überlegt.
fazit, wenn die flaschen jetzt brechen bein transport, dann geht der pc und das wasserkreislauf weiter hin.
also wer es mit echtem glass flaschen waagen will darf es gerne machen, ist neuland und hat risiken, aber da ich mein case länger behalten möchte werde ich es sicher nicht so bauen. die beide reservoirs kann ich jetzt auch raus nehmen in ein stück ohne das die flaschen überhaupt angefasst werden.
dazu ommt auch das der pc hinterteil öffnet und bei fixiert in glass flaschen wäre das noch ein spannungs punkt. ;)
anyway, es kommen noch rum logos drauf, bin noch gar nicht mit die optik fertig..
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Alan-Lee« (21. Mai 2016, 09:10)
Samstag, 21. Mai 2016, 13:25
Ich hab mal nen ABG aus ner Monkey Gin Flasche gesehen.
Ich such mal das Bild.
Der hat mit 12mm Glasbohrer löcher gebohrt und dann normale 1/4" Anschlüsse reingeklebt.
Samstag, 21. Mai 2016, 13:45
war es ein flach flasche, und vor allem hat er es viel transportiert und vor vor allem gibt es den noch.
wahrscheinlich schon kaputt, das mache ich nicht. aber wurde es gerne sehen.
sachen die zu einander passen in waku bereich werden schon mal undicht. und glass bricht auch noch, nee... mein case soll leben..
